Perform this procedure to display information about Energy Saver configuration on the ports.
enable
show energy-saver interface [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
Switch:1>enable Switch:1#show energy-saver interface Port ES State PoE Savings PoE Priority ----- --------- ----------- ------------ 1/1 Enabled Enabled Low 1/2 Enabled Enabled Low 1/3 Enabled Enabled Low 1/4 Enabled Enabled Low 1/5 Enabled Enabled Low 1/6 Enabled Enabled Low 1/7 Enabled Enabled Low 1/8 Enabled Enabled Low 1/9 Enabled Enabled Low 1/10 Enabled Enabled Low 1/11 Enabled Enabled Low 1/12 Enabled Enabled Low 1/13 Disabled N/A N/A 1/14 Disabled N/A N/A 1/15 Disabled N/A N/A
